automatically setup not printable layers to not be shown in viewports.
leticia.campanelli
leticia.campanelli
Hi there,
I am wondering if there is an automatic way to setup the non printable layers to not be shown in the viewports.
I usually simply freeze them in the viewport, but for this specific project it is boing time consuming.
thanks
cadffm
not ootb, but with few lines code and the native command VPLAYER, no problem:
(defun c:AllNoPlotLayers2VPFRZ (/ a b)
  (setq b "")
  (while (setq a (tblnext "LAYER" (not a)))
    (if (zerop(cdr(assoc 290 (entget (tblobjname "LAYER" (cdr(assoc 2 a)))))))
        (setq b (strcat (cdr(assoc 2 (entget (tblobjname "LAYER" (cdr(assoc 2 a))))))"," b))
  (command "_.VPLAYER" "_fr" b "_all" "")
  (princ)
Sebastian
leticia.campanelli
feeling stupid. 😂
Thank you so much, but I have no idea how to use this code.
is it easy enough to explain it here?
cadffm
no problem.
For usual you have a .lsp (or /.fas./vlx) file with code inside, so you can drag&droop the file into your drawing or
load it by command APPLOAD (often you will see informations about loaded function names in commandline/Textscreen [F2]).
In the case here, you have the (Lisp)sourcecode only, so you have to create a .lsp file yourself:
Open EDITOR, copy&paste the code into, save as <Name of your choice, but often the part after "defun c:" is senseful 😉 > incl. the file extension .LSP
In this case here:
Save it to your new AutoCAD Custom Tools folder wherever\Tools\AllNoPlotLayers2VPFRZ.lsp
Now, you can load this file by drag&drop into your drawing or by APPLOAD command.
Note: In APPLOAD dialog, you can set up Acad to load this file into every file by open that file.
Sebastian
leticia.campanelli
thank you!!!!
