I have AutoCAD and AutoCAD MEP 2014 installed on my computer. I have a 64 bit Win 7 system. The problem Im having is when I open up AutoCAD, AutoCAD MEP comes up. Could it be something I may have done wrong during installation, should I uninstall and reinstall AutoCAD?
By default, if you double click a drawing file, Autocad Launcher will open whichever one you had opened last.
If you have AutoCAD and AutoCAD MEP installed separately, (as I do) then you should be able to launch whichever you wish by clicking on the corresponding program name in the Windows Start menu, or Desktop shortcut
By default, "AutoCAD's shortcut is
Thank you for the reply. When I say open up, I mean clicking the icon to open the application to use it. I have an icon on my desktop for 2014 Autocad and 2014 Autocad MEP. When I click on the icon for 2014 Autocad, the window for 2014 Autocad MEP comes up.
It sounds like the desktop shortcut is messed up. If you can launch AutoCAD from the Windows Start menu, then just drag that shortcut from the Start menu to the Desktop and delete the one that's not working.. (or compare shortcut properties and adjust as needed)
