AutoCAD Forum
AutoCAD - 3D polyline Line Type Style
8 REPLIES 8
Message 1 of 9
jtm2020hyo
564 Views, 8 Replies
I did not find any method to use Hidden Line Type Style with 3D Polylines.
Anyone knows how to do this task?
PD: LINETYPE3DPLINEON command already does not work. ( https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Linety... )
[ The subject line of this post has been edited to include the product name by @handjonathan ]
8 REPLIES 8
Message 2 of 9
pendean
in reply to: jtm2020hyo
Q: can you assign any other of the dozens of linetypes to it by chance?
Message 3 of 9
jtm2020hyo
in reply to: pendean
Nothing work for 3D Polylines Line Types, Hidden Lines or Dashed or anything, the LINETYPE3DPLINEON command work but only for AutoCAD Vanilla, for Civil 3D, AutoCAD Architecture or another vertical variants do nothing.
Are there any others alternatives?
Message 4 of 9
pendean
The LINK in your first post said...
Message 5 of 9
SEANT61
A spline (degree 1) could be a possible alternative.  Especially for AutoCAD versions that predate LINETYPE3DPLINEON.
May your cursor always snap to the location intended.
Message 6 of 9
jtm2020hyo
in reply to: SEANT61
Looks awesome, this is new for me, but how did you create or change the spline degree to 1?
I tried but no luck.
Message 7 of 9
SEANT61
Start the SPLINE command and choose the Method sub-option, Select CV. Then select the Degree sub-option and input 1.
Message 8 of 9
jtm2020hyo
is there way to convert a >1 degree Spline t 1 degree Spline? I did not found anything
Message 9 of 9
SEANT61
Use the _CVREBUILD command
AutoCAD Inside the Factory
