I did not find any method to use Hidden Line Type Style with 3D Polylines.
Anyone knows how to do this task?
PD: LINETYPE3DPLINEON command already does not work. ( https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Linety... )
[ The subject line of this post has been edited to include the product name by @handjonathan ]
Solved by SEANT61. Go to Solution.
Nothing work for 3D Polylines Line Types, Hidden Lines or Dashed or anything, the LINETYPE3DPLINEON command work but only for AutoCAD Vanilla, for Civil 3D, AutoCAD Architecture or another vertical variants do nothing.
Are there any others alternatives?
The LINK in your first post said...
A spline (degree 1) could be a possible alternative. Especially for AutoCAD versions that predate LINETYPE3DPLINEON.
Looks awesome, this is new for me, but how did you create or change the spline degree to 1?
I tried but no luck.
is there way to convert a >1 degree Spline t 1 degree Spline? I did not found anything
