AutoCAD Forum
AUTOCAD 2023 CRASHING IN 3D WHEN I TRY TO BLEND TWO LINES
6 REPLIES 6
ranjit4DA5W
727 Views, 6 Replies
I tried to create a solid shape as shown and then extrated the edges
Then i removed the shown edges and wanted to blende between the curves
i get this error
Date/Time: 2022-07-05 15:20:55 +04:00
Application: acad.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: acgsf.dll
Exception Address: 0x00007ff911d71127
Exception Code: c0000005
Exception Flags: 0
Exception Parameters: 0, 0
this works fine in autocad 2022
6 REPLIES 6
sophia_lee
in reply to: ranjit4DA5W
Hi @ranjit4DA5W
I have tested the file from my end but it was not causing the crash from my end.
The error code seems like a fatal error related to installation.
First, check the update for Graphic card driver and Windows update by following;
If above is not working, kindly try reinstallation with admin permission this time;
Hope this helps!
Sophia Lee
Global Product Support Specialist
As @sophia_lee said,
it looks like the problem is not version related, I could blend the lines perfectly in Acad 2023.
The Exception Code: c0000005 actually refers to a windows issue where some RAM unit is needed by the application, but it has not been assigned to that application. This means your error could be solved by a clean uninstall / reinstall of the software or could point to a deeper issue with your Windows installation.
read the following, and when unsure - contact your IT guy:
https://www.stellarinfo.com/blog/how-to-fix-error-code-0xc0000005-in-windows/
ranjit4DA5W
Thank you for the replies. I will try them and see how it goes.
Cheers
Ranjit
In the mean time here's your design with different blended connections
You saved my day!
The error was occuring again and again and I didn't know how to fix that.
After seeing your comment I simply freed up some space on my C drive and also installed a RAM optimizer software.
Problem Solved
glad to have been of help ^^
AutoCAD Inside the Factory
