AutoCAD Forum
Copy and pasting drawings in to MS word
2 REPLIES 2
renaldy_wibisonoSHQ64
74 Views, 2 Replies
Hello!
I am currently making a report in PDF form.
The report contains chapters of words and also intensive on the drawing of parts
So far, i have been just CTRL C +V part drawings from dwg and pasting it to word, then resizing using object -> edit
and replacing all the dimension texts ( to make all the fonts the same and standard). This is a painstaking process and i was wondering if there is a better way to do this
2 REPLIES 2
With the background set to white and the drawing window sized to fit the area to copy I use the PNGOUT (Command).
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
@renaldy_wibisonoSHQ64 With your AutoCAD background set to white (unless you like the contrast in your MSWord document), use this instead then "paste" into your MSWORD document
Win10
https://support.microsoft.com/en-us/windows/use-snipping-tool-to-capture-screenshots-00246869-1843-6...
Win11
Unless you have a dire need to also store all those images from AutoCAD on your PC as well, then the tip offered by @TomBeauford is the way to go.
Technology Administrators
AutoCAD Beta
