AutoCAD Forum
AUTOCAD 2023 CRASHING IN 3D WHEN I TRY TO BLEND TWO LINES
6 REPLIES 6
ranjit4DA5W
776 Views, 6 Replies
ranjit4DA5W
I tried to create a solid shape as shown and then extrated the edges
Then i removed the shown edges and wanted to blende between the curves
i get this error
Date/Time: 2022-07-05 15:20:55 +04:00
Application: acad.exe
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: acgsf.dll
Exception Address: 0x00007ff911d71127
Exception Code: c0000005
Exception Flags: 0
Exception Parameters: 0, 0
this works fine in autocad 2022
i get this error
Exception Flags: 0
6 REPLIES 6
sophia_lee
in reply to: ranjit4DA5W
sophia_lee
Hi @ranjit4DA5W
I have tested the file from my end but it was not causing the crash from my end.
The error code seems like a fatal error related to installation.
First, check the update for Graphic card driver and Windows update by following;
If above is not working, kindly try reinstallation with admin permission this time;
Hope this helps!
Sophia Lee
Global Product Support Specialist
Hi @ranjit4DA5W
Hope this helps!
Sophia Lee
Michiel.Valcke
As @sophia_lee said,
it looks like the problem is not version related, I could blend the lines perfectly in Acad 2023.
The Exception Code: c0000005 actually refers to a windows issue where some RAM unit is needed by the application, but it has not been assigned to that application. This means your error could be solved by a clean uninstall / reinstall of the software or could point to a deeper issue with your Windows installation.
read the following, and when unsure - contact your IT guy:
https://www.stellarinfo.com/blog/how-to-fix-error-code-0xc0000005-in-windows/
ranjit4DA5W
ranjit4DA5W
Thank you for the replies. I will try them and see how it goes.
Cheers
Ranjit
Cheers
Ranjit
Michiel.Valcke
In the mean time here's your design with different blended connections
A_H_Ekhteraei
You saved my day!
The error was occuring again and again and I didn't know how to fix that.
After seeing your comment I simply freed up some space on my C drive and also installed a RAM optimizer software.
Problem Solved
You saved my day!
Problem Solved
Michiel.Valcke
glad to have been of help ^^
AutoCAD Inside the Factory
