Until today, I'd been using AutoCAD 2017, but have now been upgraded to 2022.
When it came to publishing a PDF, I notice that the margins have disappeared. I set up the pc3 printer EXACTLY the same was as I did for 2017 and used EXACTLY the same publishing method, yet in the resulting PDF there are no margins at all.
The document page layout for, named "A4", has printer named ACAD.pc3, extents, monochrome.ctb, fit to paper, center plot and A4 paper size.
ACAD.pc3 Points to my printer (the exact same printer as used on 2017) and paper sizes are filtered down to A4 and A3.
Every thing else is left at default.
Does anyone know why the resulting PDF has no margins whereas it did before? What has changed and what do I need to do to get this back?
[ The subject line of this post has been edited for clarity by @handjonathan Original: Margins disappeared when printing PDF ]
(I apologize for my earlier comments that referred to AutoCAD 2023. I don't have 2022 installed and was assuming that 2023 is not significantly different.)
"The thing is that the paper size which appears in the page setup (A3 and A4 in my case) are not reflected in the standard paper sizes in the AutoCAD PDF (High Quality Print).pc3"
I thought that earlier you had indicated that there are paper sizes with the correct dimensions but with different names. Do you not see various ISO A3 and ISO A4 paper sizes?
@dmfrazier wrote:(I apologize for my earlier comments that referred to AutoCAD 2023. I don't have 2022 installed and was assuming that 2023 is not significantly different.)
Yes the paper sizes seem to be correct but the names are not.
Instead of names such as A4 or A3, I have "ISO full bleed A4 (297.00 x 210.00 mm)", "ISO expand A4 (297.00 x 210.00 mm)" or "ISO A4 (297.00 x 210.00 mm)".
If the paper sizes match but the names do not how do you know what paper to adjust the margins on? There are at least three A4 options (as detailed above) which are all the same size and as far as I can see only differ in name and margins - how are you supposed to know which one is being used for plotting or publishing?
I don't have the option to create a custom paper size in the physical pc3 either as it is greyed out.
Hey, I've been wondering if the standard paper size in the PC3 editor has gone through any updates or if it's just different now.
