Hi there,
I have created a block in a drawing and then i made a copy to another drawing with the same layer, and de measure of block as changed.
What happened and how can i solve the problem?
[The subject line of this post has been edited for better findability by @handjonathan Original: Block measure ]
Hi there,
Hi There,
I have alreready tried, and they are both in millimeters (see image below).
I have noted that, when i copy from a drawing to another, the text doesn't change its heigh, but the simbol is shown in a much short heigh.
Hi There,
I'm afraid that you have a block with the same name in that other drawing ?
Imad Habash
Imad Habash
Yes, the block has the same name in both drawings.
Did you have the 'annotative' checkbox on when creating the block?
It might just be scale dependent and will scale different in another drawing with another annotation scales.
Check the properties of the block in the 'Misc' part there is 'Annotative',
Use BEDIT to change the value to No.
Does this change the behavior?
Check that Dimstyle / Primary Units / Scale Factor are identical for both drawings. Someone might have changed it for drafting purposes...
Hi there,
I have already tried,
The scale is the same.
When i copy a block from a drawing to another, the block text mantains the same, but the simbol appears smaller.
If you pay attention to the next two pictures below, you will note the symbol with same size than text in first picture, and the symbol smaller than text in the second picture (symbol is the litle blue square inside a circle that i have drawn).
Hi there,
Hi there,
In Misc separator it appears "no" in annotative, in both drawings. It must have appeared some scale value, like 1:1, for instance?
Even if i try to write something in anotative, it is not possible.
Hi there,
@sergiolordelo342V2
If the value for 'Annotative' is set to 'No' this means the block is not scale dependent.
The only way for anyone to check now is if you could share both dwg's for anyone to inspect the differences between both drawings.
@sergiolordelo342V2
