AutoCAD 2019 removed FBX import and export
Alfred.NESWADBA
Consultant Consultant
Message 1 of 63
Alfred.NESWADBA
I just want to mention for all thinking about updating to 2019 that FBX can't be imported and can't be exported any more.
Also discussed >>>here<<< as I use it quite often to exchange data between Infraworks and Civil 3D. But there are some other reasons too to need FBX import and export.
For me it's not an upgrade, it's a downgrade when a new version of a product can do less than the previous one. Really sad with that.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Replies (62)
Message 21 of 63
BSchwartzkopf
What about a Navisworks workflow? I can't get items into Autocad now from my NWD's. I thought Autocad didn't remove commands once in the program.
Message 22 of 63
Alfred.NESWADBA
in the meantime they have published an add-on >>>there<<<
- alfred -
Alfred NESWADBA
Message 23 of 63
BSchwartzkopf
Thanks!!
Message 24 of 63
JamesMaeding
wow, we are seeing internal struggles at Adesk.
They seriously made an additional tool for a significant feature they removed, I have never seen that happen.
Might be because Mr Bricscad does have fbx import and export???
Competition is good folks, thank you bricsys!
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Message 25 of 63
Fage not found !
How can get file AutodeskAutocad2019fbx64.exe  ?
Message 26 of 63
marie-pierre.lebel
Message 27 of 63
JamesMaeding
@marie-pierre.lebel @Anonymous
I posted it here since they do seem to have removed it.
fbx add-on
BTW, I use it for infraworks and last Friday thought maybe there was a better workflow for getting 3d solids into it.
I tried the "add 3d drawing" approach and got this malarky "you must have a bim 360 account" message and got rejected. So back to FBX. Adesk's creativity at getting us to jump through cloud hoops is getting quite slimy.
Message 28 of 63
Beka_Tchigladze
So, What about Autocad 2020 is there opportunity to export .FBX? I need it like an air every time, what the crap is that I did not understand really, I don't want to use naviswork, is there any new ADD ons to install on my Autocad or Autocad civil? or how can I export 3D textured models for infraworks? anybody has any idea? can anyone give me advise?
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
Message 29 of 63
Alfred.NESWADBA
You can't, and for me that seems more like the start of the end.
In Infraworks DWG import does not handle textures (neither via cloud nor via Navisworks), so all my content (e.g. traffic signs) I made in 3D can't be transferred any more.
I don't know how Autodesk thinks about ignore AutoCAD 3D data for Infraworks.
I'm very sad and disappointed about that.
- alfred -
Alfred NESWADBA
Message 30 of 63
Beka_Tchigladze
I have same problem I have lots of road signs and textured retaining walls and sort of things like power lines and so on, how can I import all this staff? how would you import all this staffs in infraworks?
Beka Tchigladze
Message 31 of 63
Alfred.NESWADBA
Currently I use AutoCAD 2018 (or 2019 with plugin).
Autodesk recommends to use 3DS-Max, but on one side I can't run my automated way from AutoCAD to InfraWorks using this step, on the other side textures are many times incorrect mapped (assigning mapping coordinates to an AutoCAD object is not correct transferred to 3DS-Max). So it is not really an alternative.
We have to look now for different approaches, either to find a way from AutoCAD to InfraWorks or an alternative to InfraWorks. If you simply want to use InfraWorks as a real-time viewer of Civil 3D projects with a it live in the scene there are a lot of alternatives. The critical part with that is that exchanging data to other systems are also based on FBX (as this is a great exchange standard in the meantime, it might be too bad to think that this could be the reason why AutoCAD cut it).
- alfred -
Alfred NESWADBA
Message 32 of 63
Beka_Tchigladze
So I have installed Navisworks Manage and I have tried it for just one example yet,  it works perfect, materials appears great. are you kidding me? Smiley Very Happy I have installed whole software for just one exporting, what a pity.
Beka Tchigladze
Message 33 of 63
Beka_Tchigladze
does this Plugin works for Civil 3D 2019?
Beka Tchigladze
Message 34 of 63
This is file AutodeskAutocadFBX2019_64.exe but it was removed by Autodesk last month
Message 35 of 63
Beka_Tchigladze
I have this plug in I just wander if it fits on Civil 3D 2019
Beka Tchigladze
Message 36 of 63
Alfred.NESWADBA
Yes.
But ridiculous enough, Autodesk removed this plugin.
I would never understand why removing an addon that was working well and needed (from Autodesk's customers!). For me this looks like blocking these users (their customers) intentionally.
- alfred -
PS: I don't use such wording regularly, but sometimes Autodesk's decisions really hurt.
Alfred NESWADBA
Message 37 of 63
Beka_Tchigladze
Thank you for response Alfred I will use this plug in and use nice old 2019 version.
I think it is business action, you should buy additional software's to manage project.
Beka Tchigladze
Message 38 of 63
skylardaniels
Alfred,
If you have access to Navisworks Simulate 2019 or later, below is a link to a Navisworks app that allows you to import objects directly from Navisworks to AutoCAD in real time. It makes referencing objects in a Federated model relatively easy.
While it is currently not optimized for large exports (either a lot of objects, or very complicated object geometry), it will work. There are plans to add the ability to export a file out of Navisworks to disc, then import  into AutoCAD in a future release which should hopefully make it more efficient for very large imports.
Navis To Acad
Message 39 of 63
Alfred.NESWADBA
May I ask what this app has to do with the missing FBX-Import/-Export?
- alfred -
Alfred NESWADBA
Message 40 of 63
JamesMaeding
@skylardaniels
Export in future to what format? Do you mean you have written your own fbx add-on?
Given that adesk wrote their own add-on for 2019, this is all silliness. Clearly the libraries needed are available yet adesk took out the feature for business reasons. Or would adesk care to get specific on technical reasons it was removed?
