AutoCAD Forum
AutoCAD 2018 freezes on opening
13 REPLIES 13
Message 1 of 14
1260 Views, 13 Replies
I have AutoCAD 2018 Student Version product. Every time I open the software it will freeze on the start screen and it won't even close. I tried reinstalling, repairing the software but nothing works. I also tried all the solutions available on the forum but no luck. Can anyone please help me?
john.vellek has embedded your image(s) for clarity
13 REPLIES 13
Message 2 of 14
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Can you proceed to install the updates that appear in that notification?  You can get them from your Autodesk Desktop App or through your Account page.
Then, tell me about your OS and your graphics card. I would like to see if this is just a driver issue.
When this starts does it appear to get through the license check?
John Vellek
Message 3 of 14
in reply to: john.vellek
Hi @john.vellek
OS : Windows 10 Home Single Language
Graphics Card : 1. Intel(R) HD Graphics Family  2. AMD Radeon R5 M330
It was working a few days back but now it won't proceed from that screen.
Message 4 of 14
john.vellek
Hi @Anonymous,
Can you tell me the build version of your OS by typing WINVER in the run line?
This link should give you access to the most current graphics driver.  Can you also try running with the No Hardware Switch to see if that helps?
You should also check your Windows updates to see what had just been installed.
John Vellek
Message 5 of 14
Hi @john.vellek
MS Windows Version 1709(OS Build 16299.248) i have tried the /nohardware and /SAFEMODE, but niether of them worked.
Message 6 of 14
john.vellek
HI @Anonymous,
Please try removing the KB4074588 from your OS and let me know if that gets things back to normal.  It seems to be causing some issues for a variety of applications.
John Vellek
Message 7 of 14
Hi @john.vellek
Can you explain the procedure of how to uninstall the update.
Message 8 of 14
rkmcswain
Thanks @john.vellek - is there an Autodesk KB article on this?
Message 9 of 14
john.vellek
in reply to: rkmcswain
Hi @rkmcswain,
I know that one was in the works but I am not sure if it has been published yet.  The .214 build seemed to remedy a bunch of problems but the .248 build seemed to create some new ones.
I will post a link as soon as I can find the article.
John Vellek
Message 10 of 14
john.vellek
HI @Anonymous,
  • At the run line (at bottom left of screen where it says "Type here to search" enter Control Panel.
  • Once this window opens, select Uninstall a program from the Programs category.
  • On the left side of the resulting window, select 'View installed updates".
  • You should now be able to scroll to find the KB.
  • Once you find it, select the KB and then click "Uninstall"
John Vellek
Message 11 of 14
john.vellek
Hi @rkmcswain,
I am still waiting to see if an article will be written for this issue but now that the newest .251 build version is out it appears that might fix some of the issues from .248
John Vellek
Message 12 of 14
hi @john.vellek
your solution with trying installing the .248 worked out. But the system keeps on auto-updating itself even after overriding it. Is there any other solution to this problem?
Message 13 of 14
john.vellek
Hi @Anonymous,
Depending on the exact version of Windows 10 that you are using, you might be able to block updates from auto-installation.  There is a .251 build available now and some customers report that it seems to behave properly. You might try that version too.
In addition, I believe that .309 was also released on March 13th.
John Vellek
Message 14 of 14
hi @john.vellek
I tried with .309 but I'm facing the same problem
AutoCAD Inside the Factory
