AutoCAD Forum
Base view commad not working...
19 REPLIES 19
Message 1 of 20
4423 Views, 19 Replies
I've just recently been having a problem with the base view command.  While trying to create the base view from model space all I get is the move command.  Also from inventor the command changes to fillet.  Has anyone expierience this problem or is it just me?  I've uninstalled AutoCad 2013 completly then reinstalled but continue to have the same problem.
Steve
19 REPLIES 19
Message 2 of 20
Alfred.NESWADBA
welcome @forums.autodesk.com!
Can you start that procedure again, on the end press <F2> so the "long"-text-screen pops up with more lines to see some history about what happend .. let us see the content of that.
If you can upload the drawing you are working with, it might help too.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 20
in reply to: Alfred.NESWADBA
Alfred,
Thank you for your reply.  Inventor server failed to load...
Steve
Message 4 of 20
What needs to happen to fix this problem?
Message 5 of 20
Alfred.NESWADBA
can you show the command-line content?
I never had the situation the the viewbase command breaked and started move ... so I guess there might be some info between the lines/between the command lines.
- alfred -
Alfred NESWADBA
Message 6 of 20
I'm not sure how.  Print screen didn't work and when I tried the snip tool the command bar goes away.
Message 7 of 20
Took a picture with my phone...
Message 8 of 20
Alfred.NESWADBA
look to that thread >>>click<<<.
HTH, - alfred -
Alfred NESWADBA
Message 9 of 20
Good morning alfred,
ModelDoc is listed on mine and that poster was experiencing a different problem after reinstalling the software.  But, I too had the "ribbons" disappear but I ended up customizing a toolbar to add the commands that wandered off, re installing the software at least brought them back but now having this command switcherroo problem.  The frustration continues and falling behind with work.  But, thanks for your efforts though.
Steve
Message 10 of 20
Alfred.NESWADBA
>> but I ended up customizing a toolbar [...] but now having this command switcherroo problem
I would start now to verify if the installation is ok by creating a new Windows user account, login with that account and try if _VIEWBASE is then working.
If that is working it's either your AutoCAD profile or your customization, but the AutoCAD installation is verified.
If that is working you might also export the AutoCAD profile (under command _OPTIONS ==> Profiles) and import that profile within your Windows account, so you can then switch between 2 profiles to get one step further with the isolation of that issue.
- alfred -
Alfred NESWADBA
Message 11 of 20
Alright I'll give it a try.  When I first uninstalled AutoCAD/Autodesk I didn't know if any of the Microsoft programs also needed to be uninstalled as well.  When I reinstalled I noticed some of those Microsoft programs being installed as well.  Could this be my problem?  The Microsoft programs listed are Silverlight, SQL server 2005, a bunch of visual C++... and MSXML 4.0 SP3 Parser.  I'm afraid to uninstall anything when I don't know what it's for.
Message 12 of 20
alfred,
I created a new Windows users account but continue to get the same errors. I swithed back to my original account to find a Heidi module load error message (see attached).  ???
Best regards,
Steve
Message 13 of 20
Alfred.NESWADBA
the screenshot looks like you are running Windows 8 or 8.1? If I'm right with that ... what version exactly are you using and have you installed the latest servicepack for your 2013 version?
The message with the Heidi-driver mostly raises when AutoCAD can't communicate error-free with the driver of the graphiccard, that might be solved with installing a newer (or sometimes an older) driver for your graphiccard.
What GC do you have ... plus the additional question: does your system report to have two GC's? (e.g. a nVidia + Intel)
- alfred -
Alfred NESWADBA
Message 14 of 20
Yes I'm running Windows 8.1 and have installed the latest service packs.  The Graphics card I have now is the Nvidia GeForce GT 625 and I have installed the latest driver for that as well.  I don't think this GC is supported by AutoDesk but it should be able to work.  I've uninstalled all AutoDesk software again along with all the Windows software that loads with the AutoCad 2013 instalation and then reinstalled everything but continue to have the same problem.  Next step I guess is to refresh the operating system.  I'm thinking it must be some sort of permission issue.  Anyway, I don't have much more time dealing with this problem before I start to loose work.  Alfred, I appreciate your help with this and I'll post anything I find out...
Thank you,
Steve
Message 15 of 20
i have the same probleme
i have windows 8.1 autocad 2014
Base view from model space thats not working
the base view from the source modeldoc
Generates the base view of a model created in model space, from which all other drawing views are derived.
When i click on the base at the tab create vieuw
and next on the from model space button
The drawing vieuw creation does not emerge.
As i give the command VIEWBASE at the command line
Appairs the message inverter server failed to load.
the model doc is ok and up to date.
that wen i give the command and pres F2
Command: VIEWDETAIL
Inventor Server failed to load.
Command: *Cancel*
Command: *Cancel*
Command: VIEWBASE
Command:
Command:
Command: _VIEWBASE
Command: _M MOVE
Select objects: Specify opposite corner: 0 found
Select objects: *Cancel*
Command:
Command: _VIEWBASE
Command: _M MOVE
how do i solve the probleme??
Message 16 of 20
Wish I could help you...  I gave up and had my employer build me a new box.  Went back to Windows 7 and now have an NVIDIA Quadro K2000 graphics card.  I personally don't think the problems were due to windows 8 or the previous GC but I couldn't waste any more time trying to figure it out  If you find a solution please let me know.
Best regards,
Steve
Message 17 of 20
Alfred.NESWADBA
try this hotfix: >>>click<<<, the description is not the same, but it has to do with BASEVIEW and Windows 8.1!
HTH, - alfred -
Alfred NESWADBA
Message 18 of 20
Hi, have you solved the problem what was that? I'm havint the same problem. Can you help me.
Message 19 of 20
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
I would start to go through the recommendations within this thread and let us know what you tried and what happened. I guess that will bring you faster to a result.
- alfred -
Alfred NESWADBA
Message 20 of 20
I am having the same problem with Baseview command,
f2 says
inventor could not connect to server
then it gives me the move command.
this is extremely frustrating!
I am running autocad 2018
windows 10
with a more than capable gpu.
was there a solution to this issue?
Any help would be greatly appreciated!
AutoCAD Inside the Factory
