AutoCAD Forum
Autocad 2017 Mouse Wheel Not Panning
7 REPLIES 7
Message 1 of 8
watkins.erik
12862 Views, 7 Replies
Using:  Windows 10, Logitech M705 mouse, AutoCAD 2017
Issue:  New mouse's wheel not using Pan function when pressed down.  Tried setting MBUTTONPAN to 1, and to 0 - neither worked.  Tried changing CUI>Mouse Click>Button 3> set to "PAN" - didn't work.... not sure what else to do?
Thanks, -E
7 REPLIES 7
Message 2 of 8
Otto
in reply to: watkins.erik
Hello watkins.erik
It looks like you are looking for information related to mouse wheel panning not working. Community members with similar questions found the following article(s) useful:
MBUTTONPAN (System Variable)
Wheel mouse does not perform pan functions in AutoCAD
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 8
beyoungjr
Have you installed the Logitech mouse utilities or did you let Windows just assign the driver?  I recommend avoiding mouse utilities unless you get some major gaming mouse or 3D mouse.  I've often fought with mouse utilities (including Microsoft Intellimouse) that seem to screw up AutoCAD's mouse usage.
You can find out if the utilities are installed by either looking in the Windows Tray (icons near the clock) or in the add/removed programs (apps) area of the control panel.
Hope this helps.
Blaine Young
Senior Engineering Technician, US Army
Message 4 of 8
john.vellek
Hi @watkins.erik,
I use the M510 with no Logitech software installed. I have my MBUTTON set to 1 and it works great.
John Vellek
Message 5 of 8
watkins.erik
in reply to: beyoungjr
Installing the mouse software worked!  Set the wheel function to "middle" in the mouse's software.  I was hoping to get around having to install it, but nevertheless it worked.
Thanks! -E
Message 6 of 8
beyoungjr
Ironically that is what I had hoped for you to avoid as well.  The utilities just seem to get in the way most of the time but I'm super glad it worked out for you.
Cheers!
Blaine Young
Message 7 of 8
Had the same situation ... I had just changed out my old mouse for the M705 and installed the mouse utilities. MBUTTONPAN stopped working so I checked the settings in the mouse utilities. By default "Zoom" was selected. Once I changed it to "Middle Button" the pan function worked fine in AutoCAD ... and the zoom still worked just fine.
Message 8 of 8
ElTonioEsFeo
People:
If all else fails, try this: nothing worked for me until I went to the "channels" buttons (the buttons that allow you to pick a "channel" to connect wireless to your computer. I am usually on channel 1, so I clicked channel 2, then back to channel 1. It seems to reset the parameters, allowing you to once again use your pan command by pressing and holding the wheel. It's a very minor inconvenience, so I stopped trying to reset all the other parameters to try and make it work. Hope this helps...!
AutoCAD Inside the Factory
