autocad 2015 on windows 10
Message 1 of 8
Hey,
I've just updated to windows 10 and Autocad won't start anymore.
I get this error when trying to open it:
and a few more missing dlls after that.
Is there a fix or should i reinstall?
thank you.
Replies (7)
Message 2 of 8
ampster40
Please search the forums for all the posts just like yours...ie, next time take into consideration whether or not any required programs you need will work in a new O.S. or not - by searching around for what other people are experiencing. All we can say at this time is to try some of the following suggestions, locate the "Reset Settings to Default" link that used to be found under Win7 here, Start menu > All Programs > Autodesk > AutoCAD (version) > Reset Settings to Default. If that doesn't work, try a Repair to the install. If that doesn't work, do a full uninstall/reinstall. If that doesn't work, you may need to refer to instructions Autodesk has posted regarding a clean uninstall process, where you go in and rip out stuff out of the Registry. But those instructions will be geared towards Win7, 8 or 8.1 and may not match what you have now. If none of that works, you are on your own until Autodesk produces a possible hot fix - but don't hold your breath as there's no guarantee that will happen.
Message 3 of 8
wispoxy
Just get if here. Smiley Happy
"It is Microsoft Visual C++ 2012 Redistributable.  You need to download and install it.  It should be a prerequisite..."
http://www.microsoft.com/en-us/download/details.aspx?id=30679
Message 4 of 8
pendean
Community Legend
Community Legend
Message 5 of 8
my problem is that when I instaled the version 2015 of autocad aachitecture in midle of the installation. I got a prompt message sayin that .NET 4.5 isn`t on my computer. evryones know that on windows 10 you directly get the verdion 4.6 of .NET. then when i tryed to install the previous version it says that i already have this version on my computer...i duno what to do please help me
Message 6 of 8
M_Hensley
I would try to uninstall .NET 4.6 then install 4.5 then reinstall 4.6
Message 7 of 8
DarrenP
someone posted this workaround: http://forums.autodesk.com/t5/autocad-architecture-general/this-is-how-to-install-autocad-2015-to-wi...
DarrenP
Message 8 of 8
Emmsleys
To provide an update on this topic and thread. The following AutoCAD versions have been tested with Windows 10.
• AutoCAD 2016 is supported with the application of AutoCAD 2016 SP1.
• AutoCAD LT 2016 is supported with the application of AutoCAD LT 2016 SP1.
• The 2016 version of most AutoCAD-based verticals should be installable and perform as expected on Windows 10
Autodesk product versions of 2012 and earlier are no longer supported and are not included in considerations of Windows 10 compatibility.
The English language versions of AutoCAD 2015 and AutoCAD-based verticals should be installable if you have received the Windows 10 update, KB3081448 or later.
Other AutoCAD language versions and language packs can be installed if Windows 10 update, KB3105210, is applied prior to installation.
DWG TrueView 2015 can be installed if Windows 10 update, KB3105210, is applied prior to installation.
The 2013–2014 versions of AutoCAD products will not be supported on Windows 10. For all links and further information on this topic please read over the AKN Article
If you are having an issue with .NET or C++ please read over the AKN article and apply the correct .NET / C++ based on your AutoCAD release and operating system capacity.
Sarah Emmsley
Technical Support Specialist
