How to Reduce File Size in Autocad 2013
I know there are tons of post similar to this, but honestly, I have read also a tons of them but i still didnt got the solution. I've tried everything, Wblocks, Saveas DXF, Purge, audit, Overkill, -purge, etc. The files where reduced only around 30-100kB. And also I have another problem, I cannot copy paste anything from this files that i want ro reduce. Its either its taking time when I copy and paste something or it doesent copy at all. Is my file the problem here or my Autocad itself? By the way I am using autocad 2013.
Justin_Doughty
All of these symptoms sound like you need the DGN hotfix:
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-C2-AE-dgn-hot...
Justin Doughty
ARKANCE
Thanks man. It works..
