AutoCAD Forum
AutoCAD 2015 Circle Selection
27 REPLIES 27
Message 1 of 28
JeffLMoran
1855 Views, 27 Replies
Has anyone noticed it to be difficult selecting circles by crossing in Autocad 2015? Is ther a new system variable or is this a bug?
Jeff Moran
27 REPLIES 27
Message 2 of 28
Can you please describe (or show) what's happening for you?
I can't see any issues:
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 3 of 28
pendean
in reply to: JeffLMoran
Seems to work fine here: post a DWG sample, point to the circles in question, let's all look at your file.
Message 4 of 28
The image shown is in 2015 and is crossing all the circles, but does not select them as the same procedure in 2014 would select all the circles.
Message 5 of 28
braudpat
Hello
A few ideas :
Q1) Have you the problem with Graphic Hardware Acceleration disabled ?
Q2) Are your circles near from X=Zero & Y=Zero ?
Q3) Which graphic card on your PC ?
and which driver version ?? Which date ???
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 6 of 28
Is it possible you are in "Paper Space" and trying to select objects in "Model Space"
No problems here with crossing selection (From Right to left)
Ron
Message 7 of 28
JeffLMoran
Another example with a blank 2015 file, circle along with rectangles. The 3 green retangles are crossed and highlighted, but circles which are crossed are not.
Image from 2014
Image from 2014 all are highlighted
Message 8 of 28
JeffLMoran
in reply to: braudpat
Graphics card info!
Message 9 of 28
It works if crossing as you show when one corner falls inside the circle. Try with corners outside
Message 10 of 28
I tried exactly what you showed in your screenshot, look to that video:
I would try:
  • a different drawing with the geometry close to 0
  • verify your hardware acceleration, try both states, on and off
  • if you have a dual screen, try AutoCAD on both displays (restart AutoCAD)
  • reset your AutoCAD profile (or try to login to your Windows with another user account and see if it works then.
  • and at least see if you have a chance with gc driver update
Good luck, - alfred -
Alfred NESWADBA
Message 11 of 28
Thanks for your help!
Your animation proves it's is on my system and not a bug.
I have tried Hardware both on & off, geom. close to 0,0,0
& switching to out-of-box profiles. No luck.
I greatly appreciate your time! Thanks again!
Message 12 of 28
maybe a repair-installaton of AutoCAD is a help, at least really try to update your gc-drivers (and look to the certified drivers >>>here<<<).
- alfred -
Alfred NESWADBA
Message 13 of 28
It's frustrating when things work on what ever version. Upgrade and thing that were fine are now broke! Arggg!
Message 14 of 28
Had this same problem
So in the registry renamed
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R20.0
Then restarted AutoCAD and it reinitialised. Then behaved ok, even after reimporting profile that wasn't working before the registry reset.
Message 15 of 28
Thanks Graham!
What did you rename "HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R20.0" to?
Message 16 of 28
Anything - I just put an o on the end. It then doesn't see the original name so reinitialises when you start AutoCAD next time.
Message 17 of 28
Thanks! I did try that and the problem still exists. I'm going to try a re-install!
Message 18 of 28
I just did a full uninstall/reinstall and problem still exists!!!!
I'm going back to 2014!!!!
Thank you all for your help!!!!
Message 19 of 28
Oops!
Sorry for any confusion - Tmoscollic and JeffLMoran are the same person Me (Jeff).
Had to log on with different name for the re-install
Message 20 of 28
hi Jeff,
I'm assuming you did the reinstall (by the name change) and have 2015 installed.  During the install did you import a profile/settings from 2014?
If so, try doing a "Reset to Defaults" and see if that fixes the issue (you will loose all of your customizations).
Forma Design Contest
AutoCAD Beta
