Has anyone noticed it to be difficult selecting circles by crossing in Autocad 2015? Is ther a new system variable or is this a bug?
Jeff Moran
Can you please describe (or show) what's happening for you?
I can't see any issues:
- alfred -
The image shown is in 2015 and is crossing all the circles, but does not select them as the same procedure in 2014 would select all the circles.
Hello
A few ideas :
Q1) Have you the problem with Graphic Hardware Acceleration disabled ?
Q2) Are your circles near from X=Zero & Y=Zero ?
Q3) Which graphic card on your PC ?
and which driver version ?? Which date ???
Patrice BRAUD
Is it possible you are in "Paper Space" and trying to select objects in "Model Space"
No problems here with crossing selection (From Right to left)
Ron
Another example with a blank 2015 file, circle along with rectangles. The 3 green retangles are crossed and highlighted, but circles which are crossed are not.
Image from 2014
Image from 2014 all are highlighted
I tried exactly what you showed in your screenshot, look to that video:
I would try:
Good luck, - alfred -
maybe a repair-installaton of AutoCAD is a help, at least really try to update your gc-drivers (and look to the certified drivers >>>here<<<).
- alfred -
It's frustrating when things work on what ever version. Upgrade and thing that were fine are now broke! Arggg!
Had this same problem
So in the registry renamed
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R20.0
Then restarted AutoCAD and it reinitialised. Then behaved ok, even after reimporting profile that wasn't working before the registry reset.
Thanks Graham!
What did you rename "HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R20.0" to?
Anything - I just put an o on the end. It then doesn't see the original name so reinitialises when you start AutoCAD next time.
I just did a full uninstall/reinstall and problem still exists!!!!
I'm going back to 2014!!!!
Thank you all for your help!!!!
hi Jeff,
I'm assuming you did the reinstall (by the name change) and have 2015 installed. During the install did you import a profile/settings from 2014?
If so, try doing a "Reset to Defaults" and see if that fixes the issue (you will loose all of your customizations).
