AutoCAD 2014 - Quick access toolbar missing
Message 1 of 24
Hello, wondered if anyone could help with this - my quick access toolbar appears to have disappeared, have checked back through some previous threads on this but have not found a solution that works, have even tried reinstalling, but it still remains absent.
Any help/ suggestions are much appreciated.
Replies (23)
Message 21 of 24
Tried resetting to default, but doesn't seem to have made a difference.
Message 22 of 24
chriscowgill7373
If reset to default didn't work, there is something bigger going on.  a reset should have put every thing back the way it was when you first opened the program.
I'm out of ideas.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 23 of 24
pendean
Community Legend
Community Legend
AutoCAD2014 is not supported in Win10 so there is one strike against you http://autode.sk/1IY4C2X
Why does it say EXPRESS in the bar above the Ribbon? I suspect that is your QAT, it's been edited.
Did you try this:
1) Open the CUI (type CUI at the command line)
2) In the top left window, highlight your workspace
3) In the top right panel, click "Customize"
4) In the top left panell, click the "+" symbol next to Quick Access Toolbar
5) Put a checkmark in the box
6) Click "Apply" and "OK" at the bottom of the CUI palette.
If not, its time to reinstall and install SP1 update for R2014 as well.
Have you tried updating the video card drivers yet? do so.
Do you have a Quadro K1100M video card? Read this https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Quick-Access-Toolbar-mis...
Message 24 of 24
I think, as someone previously suggested, the problem may been caused by a windows update, my machine performed an automatic update a few weeks ago (I hadn't used AutoCAD since). Have now updated the graphics card drivers which seems to have fixed it.
- Thank you to all that replied.
