AutoCAD 2014 - Quick access toolbar missing
Message 1 of 24
Hello, wondered if anyone could help with this - my quick access toolbar appears to have disappeared, have checked back through some previous threads on this but have not found a solution that works, have even tried reinstalling, but it still remains absent.
Any help/ suggestions are much appreciated.
Replies (23)
Message 2 of 24
chriscowgill7373
Is it just missing from the workspace or is it missing from the program?
At the command line type CUI a dialog will appear, top left quad choose your current workspace, top right box click Customize workspace
Top left quad expand out quick access toolbar and make sure there is a check on it.
Top right quad click done
Click ok at the bottom
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
Message 3 of 24
Thanks for reply - but this doesn't seem to work.
Message 4 of 24
chriscowgill7373
can you share some screenshots or a screencast of what you are seeing?
The farthest back I can test is 2015, but here is a screencast of the steps I provided:
http://autode.sk/2HxkwlN
Message 5 of 24
TheCADnoob
What happened that might have caused this? did you (or automatically by windows) by chance update a video card driver, and OS update etc.
CADnoob
Message 6 of 24
Try this:
Command "-TOOLBAR" "TOOLBAR NAME OR SELECT ALL".
- Select "Accept as Solution" if it has solved the problem. This will help other users to find an answer.
Message 7 of 24
rkmcswain
@Anonymous wrote:
Try this:
That is for regular toolbars. The QAT is different and this does not apply.
R.K. McSwain     | CADpanacea | on twitter
Message 8 of 24
pendean
Community Legend
Community Legend
Select a different workspace then comeback to your workspace, does it re-appear?
If not, CUI command
Select your workspace
in the right pane, do you see QAT listed under WORKSPACE CONTENT?
Message 9 of 24
Hello - yes under each workspace QAT is still listed in the content, but remains invisible for some reason.
Message 10 of 24
chriscowgill7373
have all the tools been removed from the QAT, so it is actually there, but blank?  a screenshot of what you see in your CUI editor would go miles for helping us to get you a solution.
Message 11 of 24
Sorry - have uploaded a screen-grab, as requested.
Message 12 of 24
chriscowgill7373
thank you.  what does it look like in the top left if you click on the + next to Quick Access Toolbars?
Message 13 of 24
Here is a screen-grab with QAT expanded...
Message 14 of 24
chriscowgill7373
Thank you, that is helpful.  try editing your workspace, remove the qat, click done, then ok.   then go back in and add it back in again.
Message 15 of 24
Sorry - possible stupid question - how do I remove it? It says to check the options to add to the workspace, but there are no boxes to check. Included another screen grab.
Message 16 of 24
chriscowgill7373
From that window, click the plus on the quick access tool bar on the left side and uncheck the box.  I believe you can also right click on an element in the top right quadrant and select an option to remove it
Message 17 of 24
Ok... doesn't seem to have worked.
Message 18 of 24
pendean
Community Legend
Community Legend
Post a screenshot of your entire fully open AutoCAD program window please.
Message 19 of 24
Ok...
Message 20 of 24
chriscowgill7373
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
I'm not sure if it is available in 2014, but if it is, I recommend reset to defaults.
