AutoCAD Forum
AutoCad 2013 won't let me specify the length of a line
16 REPLIES 16
Message 1 of 17
40380 Views, 16 Replies
I have used AutoCad for a few years and I installed 2013 to my laptop recently. I immediatly noticed something was wrong. I noticed that I couldnt specify how long a line should be. It seemed like an easy fix, I tried everything I can think of but I cant fix it. When I select the line tool and specify the base point and type how long it should be i.e. 3' and a red box apears around the dimenion box and the line isnt drawn. I tried not specifying a unit of length and it draws the line just fine. But for some reason it wont complete the line if I specify feet or inches. Help me!!
I attached a JPEG screen shot of what is going on, I hope it helps!
Thanks!
16 REPLIES 16
Message 2 of 17
maxim_k
Welcome to Forums!
You have to change units type in drawing (default units are decimal):
Use UNITS command and select Architectural or Engineering in units type drop-down:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 17
in reply to: maxim_k
That worked! Thanks so much!
Message 4 of 17
Every time I enter a command, it won't let me type a number period. I can't even click on the numerical value box. Any command, any at all, it keeps popping up the secondary menu options and won't let me tab through functions. What is happening?!
Message 5 of 17
JDMather
dynmode = ?
Message 6 of 17
lkramer212
Hello, I am having the same problem I tried your solution and it did not work. Also for my job I am instructed to dimension in Architectural Units. Does your suggestion change the DIMSTYLE? I can't even enter in a designated length for a line. It's very frustrating any help you can provide would be much appreciated, thanks!
Message 7 of 17
lkramer212
in reply to: JDMather
If this is the solution can you please let me know what the value should be? Mine said -3. Thanks for your help.
Message 8 of 17
pendean
in reply to: lkramer212
A minus means it's off.
-3 off
3 on
Change it?
Message 9 of 17
JDMather
dynmode F1
Message 10 of 17
I had the same problem, turns out my NUMLOCK was off!! I did learn about dnymode though! Thanks everyone.
Message 11 of 17
gotphish001
There's a dynomode button on the bottom tool bar. It's usually near the left side of the bar near where you can toggle paper/model space. I think by default the button is off though. You need to hit the 3 horizontal lines in the very bottom right of screen to bring up the list then make sure dynamic input has a check mark next to it. If not check it and it will add the button to the bottom bar.
Nick DiPietro
Cad Manager/Monkey
Message 12 of 17
First set your units to Arch.
Next type DDIM
Modify your dimension.
In modify select Primary Units and select Architectural.
Hit ok, Set as current, exit
Hope this helps!
Message 13 of 17
Hi, I'm going through the same problem, dyn mode worked for me, but while using the offset command entering feet is again a problem, I'm doing double work whenever I'm using the offset command.
Message 14 of 17
JDMather
Can you attach *.dwg file here that exhibits this behavior?
Message 15 of 17
 I'm also experiencing the same problem.  I tried the solutions you suggested above, but this didn't work. After typing the length of the line in the command row nothing happens. I tried not specifying a unit of length and it draws the line just fine. But for some reason, it won't complete the line if I specify centimeters. I'm working on a mac. Thank you in advance.
Message 16 of 17
pendean
The dedicated MAC forum is over there https://forums.autodesk.com/t5/autocad-for-mac/ct-p/4051
Message 17 of 17
sreynoldsWXUVZ
This was my problem today, thanks for this!
Forma Design Contest
AutoCAD Beta
