AutoCAD 2013 specific color doesn't plot
Message 1 of 26
I hope I can explain my issue correctly....
I use the color magenta for different specific layers, set to print black.  It doesn't seem to matter which layer I use it for but it never plots.  For instance, I have an elevation layer that uses magenta, a plan layer -- it doesn't plot out if the layer is assigned the color magenta.  If I change the color of that specific layer to anything else, yes it will plot.  If I set up a new layer and assign magenta to it, it will not print.  Magenta is the only color I have an issue with; every single other color works correctly.
I have checked up and down, the plot settings for those layers are set to print, I've checked everything I can think of.
Any ideas?  One layer I use it for is rather vital.
Replies (25)
Message 21 of 26
john.vellek
Hi @Anonymous,
Have you been able to do the eTransmit? Or, if you like, I can send you a private upload area so I can examine the file(s).
John Vellek
Message 22 of 26
Thanks for checking back.  I haven't had the chance, my apologies, but for the moment it seems to be working properly.  I'm not sure why or what's different.  I will come back if I find the issue again.  Thank you for your offer of assistance, I greatly appreciate it.
Message 23 of 26
john.vellek
Hi @Anonymous,
I'm glad to hear that the problem has resolved itself. Please don't hesitate to come back for help if it rears its ugly head again.
🙂 Have a good weekend
John Vellek
Message 24 of 26
Ok, I'm back!  In this particular drawing that I've attached, it's the layer ELEV-MAGENTA.  The layer is viewable in model space but disappears in paper space.  I'm very interested to learn why this happens.
Thanks so much!
Becky
Message 25 of 26
Patchy
You confused a lot of readers by saying it's only a color that can't print. it's a layer got FROZEN thru the viewport.
Message 26 of 26
Well now I feel stupid.  It wasn't like that before and everything is normally on, otherwise I would not have come to the forum.  Thanks for pointing that out!
