AutoCAD 2013 specific color doesn't plot
Message 1 of 26
I hope I can explain my issue correctly....
I use the color magenta for different specific layers, set to print black.  It doesn't seem to matter which layer I use it for but it never plots.  For instance, I have an elevation layer that uses magenta, a plan layer -- it doesn't plot out if the layer is assigned the color magenta.  If I change the color of that specific layer to anything else, yes it will plot.  If I set up a new layer and assign magenta to it, it will not print.  Magenta is the only color I have an issue with; every single other color works correctly.
I have checked up and down, the plot settings for those layers are set to print, I've checked everything I can think of.
Any ideas?  One layer I use it for is rather vital.
Replies (25)
Message 2 of 26
Patchy
Could be the screening, use 100
Message 3 of 26
Hadn't checked that, thank you.  They're all set to 100 including magenta.  Thanks for the idea!
Message 4 of 26
Patchy
Maybe using ETRANSMIT make a zip file and attach (only the part that has magenta layers or lines needed) someone will get it fixed for you.
Message 5 of 26
pendean
Community Legend
Community Legend
Color 6 "magenta" does not print to what device or using what driver?
Does it also not print if you plot to the DWG TO PDF driver? Even if you set the Plot Style Selection to NONE?
Or is that layer set to NOPLOT? Of did you draw everything in "megenta" on layer DEFPOINTS?
You're not explaining it well, you left out a lot of possiblities.
Message 6 of 26
Patchy
Or Shut down and reboot the PC, sometimes it helps.
Message 7 of 26
Thanks -- I shut down and/or reboot every day and the problem still persists.  I appreciate the thought though!
Message 8 of 26
Color 6 magenta does not plot to any device using any driver.  It doesn't print to my printer at home, a regular HP inkjet printer, and it does not plot to the HP DesignJet plotter at work, nor the Xerox copier.  It does not plot when I do DWG to PDF either.  The lines I've drawn using magenta, regardless of what layer it is on, do not show when I plot something, they are completely missing as if I hadn't drawn them at all.
I haven't changed the plot style selection to "none" as I don't use that; I use a custom plot style setup that incorporates magenta as a specific line weight.
All the layers I use magenta for are set to plot as I mentioned; the light bulb is on, the asterisk is not shaded, it shows as plotting in the layer manager.  I don't use DEFPOINTS for anything.
Thanks, I hope that's clearer.
Message 9 of 26
How would I go about that and who would fix it?  Thanks.
Message 10 of 26
john.vellek
Hi @Anonymous,
Please eTransmit a sample file so I can see if this is a behavior I can duplicate.
John Vellek
Message 11 of 26
pendean
Community Legend
Community Legend
>>>...I haven't changed the plot style selection to "none" as I don't use that...<<<
Don't care what you do normally, this is a test. Choose NONE and try it. Find out, testing means doing something different.
Your next step is to post the DWG file along with your plot style table so we can take you out of the testing phase if you are not able to follow simple test instructions.
Thanks.
Message 12 of 26
Patchy
Any readers here can try to fix it, that's the reason I suggested posting a .dwg only with a magenta line and your plot style table using ETRANSMIT command.
Message 13 of 26
Thank you very much, I appreciate it.  I have never tried ETransmit so if you could point me in the direction of some directions, I'd greatly appreciate it.  Thank you.
Message 14 of 26
pendean
Community Legend
Community Legend
Message 15 of 26
Goodness me, no need to get snippy.  You did not say test this theory, you asked if I had tried it previously which I had not as I have no use for "none."  Please don't respond if you are going to be difficult.  I have plenty of other things to do than deal with angry internet people insinuating I'm an idiot.  Thanks.
Message 16 of 26
pendean
Community Legend
Community Legend
Not snippy, just reminding you a test is a test since what you normally do is not really working. Hope that explains it better.
Message 17 of 26
Do I eTransmit to here or do I need to send the file somewhere?  I work freelance for a firm and would prefer not to have their information available for everyone to download for privacy reasons, if that's possible.  I appreciate the understanding.  Thank you.
Message 18 of 26
pendean
Community Legend
Community Legend
Use SAVEAS command to create a sample file: delete client info from the file he PURGE it. Now use eTransmit command on this new file.
You eTransmit to a ZIP file on your PC, then come to this website and post that as a file attachment.
Off topic slightly: how long have you actually used AutoCAD for? I'm thinking we all need to simplify our answers for you moving forward if you're very new.
Message 19 of 26
I will purge as much as I can then.
I have never had any need to eTransmit.  And much longer than you're assuming, thank you.
Message 20 of 26
pendean
Community Legend
Community Legend
I assume nothing about anyone, just asking: we all have learning moments every day we are alive, no exceptions.
