Attribute Text Size Not Matching Text Size
christopher.mckay2AXF5
966 次查看
4 条回复
1 条消息(共 5 条)
I am trying to get the text size in an attribute in a block to match the text above it. The text above it has the same text height (1/8") as the attribute, same text style, same width factor. But the text is noticeably different (see screenshot below).
Has anyone run into this issue before?
0 个赞
已接受的解答 (1)
967 次查看
4 条回复
回复 (4)
2 条消息(共 5 条)
pendean
Community Legend
Community Legend
Share the actual DWG file with the block with issue in it please.
0 个赞
3 条消息(共 5 条)
Sure thing. I'm trying to make a new title block to use for layout drawings. This .dwg should be stripped down, the issue can be seen in my rev block and then on the "Notes" option for toggling visibility between Approval/Notes
0 个赞
4 条消息(共 5 条)
pendean
Community Legend
Community Legend
已接受的解答
Do this first in UNITS command so AutoCAD can stop rounding as you've asked it to do with your current setting to see true sizes of things in your file
0 个赞
5 条消息(共 5 条)
Thank you! That did the trick, I got it to match now. Had no idea that when I entered 1/8" that some of them were rounding down to 7/64.
0 个赞
