This makes no sense whatsoever, why does the attribute just go wherever it wants when the block is in model space and is there anyway to control its position in the model space.
Solved by GeeHaa. Go to Solution.
Did you Lock the position of the attribute? click on the Attribute in the block editor. Lock position is near the bottom of the list.
