attribute inversion problem
nosurvive
nosurvive
hi, I am having a problem as shown in the attachment.
The two cases come from the same block definition, telecom_manhole. The attributes appear upside down in case 1 using the BEDIT and ATTSYNC method, while the case 2 using inserting block via definition has no problem. I don't why and how to fix it.
Can anybody help me with this problem ? thanks in advance 🙂
cadffm
Rotate the block reference by 180,  or change the rotation in your property palette [CTRL+1] to 0.
Sebastian
imadHabash
I doubt that BEDIT will do that because your origin block is correct .. all what you need now is to modify your upsidedown block from Propertied palette ( Ctrl+1 ) .
Imad Habash
nosurvive
I see, that was because i rotated the block at a angle of 180 during the insertion. Thanks a lot )
