Data Extraction/Dynamic blocks: Can I count rows or columns in an array action?
cgooding
cgooding
I created a dynamic block that I can array using these instructions:
https://www.youtube.com/watch?v=NgPuhIh_aSk
Why can't I just tell it to give me the number of rows or columns in the array that it creates?
cadffm
>>"Why can't I just tell it to give me "
Select the parameter, action or blockreference - can you see any row or column property?
No, because there aren't and because of this - you can't just tell them to give you.
(Note: You are in a user forum, not in autodesks office / support hotline)
You can use fields to calculate the value you want, if you need simple row/columns,
precision0, distance/step length = your value.
Sebastian
cgooding
Thanks for your reply. I should have been more specific:
If I create an array using the array command, NOT in a dynamic block, I can select the array and the properties of rows and columns are right there in the properties panel.
So, being naive, I thought that the array action in dynamic blocks is creating rows and/or columns in a similar manner, and therefore the data of "how many rows/columns are there in this array" must exist somewhere.
My question should have been "can I access that data"?
I suspect from your previous reply that the answer is "NO", and that the way those 2 different array functions work is totally different. But I want to be certain.
cadffm
You got the answer,
look into the properties palette - it is not the same.
You create the same inside a block, but you are talking about the array parameter and this isn't the same.
Sebastian
