Attached image lost when reopening the dwg file
Message 1 of 8
I have a dwg file with an image attached to it. When i close and reopen the dwg file, the image is lost and what is left is an image border w/ its directory location. I know that when you move the image file itself to another directory and reopen the dwg file then it will be the time that only image border and location directory appears. But its not the case for me because i havent move nor modify the image file itself. So my question is, what is causing this? Help me please.
Replies (7)
Message 2 of 8
Dear MR. marklawrence21
Please find the attached screen cast and follow the steps mentioned in it to rectify your problem....
Hope this could help you out.......
Regards
Di****h.MC
Message 3 of 8
RobDraw
What kind of pathing are you using?
Was the referencing file saved or moved to a new location?
Rob
Message 4 of 8
john.vellek
Hi @Anonymous,
Embedded images can be problematic.
Paste Special is the command you want to explore and see which options work best for you. When you embed the image it essentially becomes an OLE type object and if the path changes in any way or is not accessible then you see this kind of problem.
My preferred method is to use an IMAGEATTACH where you have more control over the path.
John Vellek
Message 5 of 8
RobDraw
OLEs are troublesome at best and, IMHO, should be avoided unless all other options have been discounted.
Rob
Message 6 of 8
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Some members report success in embedding the image in a drawing and using it as a block.Insert that drawing into your current one and see if the image stays put.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 7 of 8
Hi I don't know  if anyone still needs this but I found a solution to this, just make sure that the location of the image you pasted in the dwg file wasn't removed or moved.
1.  Click the border of the missing image and go to the ribbon tab
2. Click external references and choose the image you want retrieve.
3.  Right click on that file and Reload and that should do the job!
Good luck! 🙂
Message 8 of 8
When I try to open dwg its not appearing even I try to relink & reload through Xref, its shows relinked but not appear in the display
