AutoCAD Forum
Assigned materials does not show up in object downloaded of BIM objects
5 REPLIES 5
kglimFE3RT
360 Views, 5 Replies
kglimFE3RT
Hello, I'm relatively new when it comes to 3d rendering in AutoCAD, I downloaded a cabinet object for use in my project which came from this link: https://www.bimobject.com/en-us/aj/product/3-drawers-unit-flexus-375x720x410mm
As I downloaded the .dwg and imported it for insertion to my project. Then I started to apply the materials I wanted into each face and nothing happens, it is still grey in realistic view. I tried to purge the materials I used to it doesn't because apparently the material is present in the project. How do I get the materials to show?
5 REPLIES 5
paullimapa
in reply to: kglimFE3RT
paullimapa
share your drawing and zip up any custom materials you applied & share that here as well
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
kglimFE3RT
in reply to: paullimapa
kglimFE3RT
Here is both the file and and screenshots of the layer panel and materials panel. The rest of the assets I used are my own.
paullimapa
paullimapa
It's drawn in some kind of block format that requires to be exploded.
After exploding it now all the objects are PolyMesh which allows me to drop materials onto
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
kglimFE3RT
kglimFE3RT
Thank you! Apparently it takes 2 explode commands to finally apply the texture, did not easily notice it though.
paullimapa
paullimapa
glad to have helped...cheers!!!
Paul Li
IT Specialist
@The Office
Paul Li
IT Specialist
@The Office
AutoCAD Inside the Factory
