Hello, I'm relatively new when it comes to 3d rendering in AutoCAD, I downloaded a cabinet object for use in my project which came from this link: https://www.bimobject.com/en-us/aj/product/3-drawers-unit-flexus-375x720x410mm
As I downloaded the .dwg and imported it for insertion to my project. Then I started to apply the materials I wanted into each face and nothing happens, it is still grey in realistic view. I tried to purge the materials I used to it doesn't because apparently the material is present in the project. How do I get the materials to show?
Solved by paullimapa. Go to Solution.
share your drawing and zip up any custom materials you applied & share that here as well
Here is both the file and and screenshots of the layer panel and materials panel. The rest of the assets I used are my own.
It's drawn in some kind of block format that requires to be exploded.
After exploding it now all the objects are PolyMesh which allows me to drop materials onto
Thank you! Apparently it takes 2 explode commands to finally apply the texture, did not easily notice it though.
glad to have helped...cheers!!!
