AutoCAD Forum
Assign value to block from text
1 REPLY 1
taitrongsong
146 Views, 1 Reply
I have an attribute block object with two tags and I have two texts, altitude and distance. How do I select the text object and assign it to the block as shown?
1 REPLY 1
paullimapa
in reply to: taitrongsong
If Kc: & Cd: are separate from attributes containing 0.04 & 8.32 which are also separate then you can use the attached llisp routine to link the source Texts each containing altitude and distance values respectively to the target attributes.
Paul Li
IT Specialist
@The Office
Technology Administrators
AutoCAD Beta
