Show only
Search instead for
I have an attribute block object with two tags and I have two texts, altitude and distance. How do I select the text object and assign it to the block as shown?
If Kc: & Cd: are separate from attributes containing 0.04 & 8.32 which are also separate then you can use the attached llisp routine to link the source Texts each containing altitude and distance values respectively to the target attributes.
