AutoCAD Forum
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Area in square feet
3 REPLIES 3
haniangel8
537 Views, 3 Replies
Area in square feet
Oneof my drawings dimensions are already in feet
When im calculating area its showing me in inches and then converting it to feet Eg like i have 9feet x 3feet
Its showing like area 27sq in (0.19sq ft) but it should be 27sq ft
3 REPLIES 3
imadHabash
in reply to: haniangel8
I suggest to modify your settings from  -DWGUNITS  command .
Drawing units =1  /  Drawing unit display formats = 4  / Architectural linear display precision formats = 4 / Scale objects from other drawings upon insert? [Yes/No] <Yes>  /  Match INSUNITS to drawing units? [Yes/No] <Yes>:  / Scale objects in current drawing to reflect change in units? [Yes/No] <Yes>: no
Imad Habash
haniangel8
in reply to: imadHabash
I have already modified it but its the same
imadHabash
Click on below image to see how it's work .. you may need to expand your command line space .
Imad Habash
Forma Design Contest
AutoCAD Beta
