Oneof my drawings dimensions are already in feet
When im calculating area its showing me in inches and then converting it to feet Eg like i have 9feet x 3feet
Its showing like area 27sq in (0.19sq ft) but it should be 27sq ft
Solved by imadHabash. Go to Solution.
I suggest to modify your settings from -DWGUNITS command .
Drawing units =1 / Drawing unit display formats = 4 / Architectural linear display precision formats = 4 / Scale objects from other drawings upon insert? [Yes/No] <Yes> / Match INSUNITS to drawing units? [Yes/No] <Yes>: / Scale objects in current drawing to reflect change in units? [Yes/No] <Yes>: no
Imad Habash
Click on below image to see how it's work .. you may need to expand your command line space .
Imad Habash
