AutoCAD Forum
Area Command - Strange Results (E+07)
8 REPLIES 8
Message 1 of 9
10499 Views, 8 Replies
When I am using the area command, the result is wrong. It appears a number and then E+07?
How can I get the right area?
8 REPLIES 8
Message 2 of 9
Slawomir_
Change length UNITS to Decimal or Architectural or etc. Currently you have Scientific.
Tags (2)
Message 3 of 9
carl.coghill
As already mentioned, you have it set to scientific notation.
FYI
1E+07 is equal to 10 000 000
Carl Coghill
Senior Designer
AutoCAD 2018
Windows 7 Professional 64bit
LinkedIn
Message 4 of 9
in reply to: Slawomir_
its not scientific. In the drawing units, it is in decimals!
why it appears that way then (E+07)?!
In general,I always need my units to be in meters. what should I be checking at the very beginning to make sure that all the dimensions are in meters?
whether i will be just measuring or i will be putting the dimensions.
Message 5 of 9
Slawomir_
It's precision. Change it to 0.00 for example and try AREA again.
Message 6 of 9
Yes it worked. The E+07 disappeared. But why the number doesn't appear in meter square? 57m2?
Message 7 of 9
Slawomir_
You use mm units in drawing as far as I remember. Change it to m. By the way you can press mark 'accept as solution' if any post solves your question.
Message 8 of 9
I changed it to meter, instead of mm. and still the area doesn't appear in metersquare. any idea?
Message 9 of 9
Slawomir_
Use -DWGUNITS command. It allows you to scale entire drawing to desired units. Experiment with it's different options, and you will find this which best suits your needs.
But first: backup your file.
Tags (1)
Forma Design Contest
