When you have a drawing and you want to calculate an area in sqm , which is the best way?
The scale is 1:100 and 1.5m in real dimensions is displayed by 15 in the DWG.
Thanks in advance
>> The scale is 1:100 and 1.5m in real dimensions is displayed by 15 in the DWG. <<
this is weird and have NO sense to be 1.5m = 15 . depending on your drawing units and i think it's Decimal (meter) the 1.5M must be either :
>> you want to calculate an area in sqm , which is the best way? <<
there is a lot of way to calculate area in AutoCAD :
Note : The total area number that you will get will be calculated depending on your drawing units ( m,cm or mm ).
Good Luck..
Imad Habash
in my test i was able to change my units to Scale inserted Content from M,cm,mm and not impact the result
my dimension style is set for Decimal with a suffix of M
I set the precision for both high for accuracy
It's in Decimal, I also provide you some photos of how exactly it is
