continuation sign
continuation sign
continuation sign
is there a way or script that makes my line as *continuation sign (i dont know how it is being called)
like at the exampleKOKqh4s
Thank you,
Aytac
Erense
Aytac,
This is known as a 'breakline' there should be a symbol available for this in the Express tools.
Or else you can create a (dynamic) block which stretches for als long as you need it.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Thank you so much
i have found it
Kent1Cooper
@Anonymous wrote:
is there a way or script that makes my line as *continuation sign ....
It's also called a "cut line."  It is one of four options for "capping" aligned parallel ends of things [even of different object types] in CapEnd.lsp with its CE command, available here.
Kent Cooper, AIA
