AutoCAD Forum
Appload Dialog Box Fills the Screen
3 REPLIES 3
WinslowNorth
235 Views, 3 Replies
I am using AutoCAD 2020 and the Appload dialog box fills the screen. lockui is set to zero. placing the cursor arrow on the edge of the dialog box (changing the cursor to a double arrow) to stretch / resize the dialog box does not work. The dialog box will not move using Alt+space, move and size are grayed out. The box will not move using the cursor.
3 REPLIES 3
paullimapa
in reply to: WinslowNorth
Looks like that arx app is corrupted have you tried resetting?
Paul Li
IT Specialist
@The Office
WinslowNorth
resetting did not help. the company has 3 versions of autocad and all are experiencing the same issue on my computer.
paullimapa
Try signing into Windows under a new account that has local admin privileges and then launch AutoCAD. But you should be able to sign into AutoCAD using your Autodesk subscription id. This is in case the Windows account you sign in with got corrupted.
Paul Li
IT Specialist
@The Office
Forma Design Contest
AutoCAD Beta
