I recently downloaded AC2019. Due to technical issue, I had to delete my AC2018 install, so I had not setting to migrate from the earlier version,. for the most part this has not been an issue with the exception of the appearance of selected geometry. I seem to recall, that formally when I selected an object(s), the line type would convert to dashed. Now the lines are converted to bold and somewhat fuzzy lines. I am wondering if there is a setting that I can change to give me a different options for the appearance properties of selected objects.
Solved by imadHabash. Go to Solution.
Hi @Anonymous,
The selection preview controls can be found in OPTIONS>Selection.
>> I am wondering if there is a setting that I can change to give me a different options for the appearance properties of selected objects. <<
you can get it by changing SELECTIONEFFECT and PRESELECTIONEFFECT system variables to 0 (zero) .
Command: SELECTIONEFFECT
Enter new value for SELECTIONEFFECT <0>:
Command: PRESELECTIONEFFECT
Enter new value for PRESELECTIONEFFECT <0>:
Imad Habash
