AutoCAD Forum
Compatibility with CorelDraw
2 REPLIES 2
902 Views, 2 Replies
I was wondering what should be done with autocad files dwg or dfx in order to make it compatible with CorelDraw? CD should accept dxf files but the pictures come out almost unreadable. Is there something that should be done in AutoCad to make the files fit for CorelDraw?
2 REPLIES 2
john.vellek
john.vellek
Hi @Anonymous,
I have not worked with CorelDraw in years but I am guessing that if the DXF file is not working very well, you might try using an older version of DXF such as R12.  What are you bringing the AutoCAD drawings into CorelDraw for? If they are just "pictures" you might print to a PDF first from AutoCAD and then bring that into CorelDraw.
John Vellek
Hi @Anonymous,
John Vellek
john.vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or question. Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
Hi @Anonymous,
John Vellek
AutoCAD Inside the Factory
