AutoCAD Forum
Appearance of selected objects
2 REPLIES 2
1081 Views, 2 Replies
I recently  downloaded AC2019.  Due to technical issue, I had to delete my AC2018 install, so I had not setting to migrate from the earlier version,.  for the most part this has not been an issue with the exception of the appearance of selected geometry.  I seem to recall, that formally when I selected an object(s), the line type would convert to dashed.  Now the lines are converted to bold and somewhat fuzzy lines.    I am wondering if there is a setting that I can change to give me a different options for the appearance properties of selected objects.
2 REPLIES 2
john.vellek
Hi @Anonymous,
The selection preview controls can be found in OPTIONS>Selection.
John Vellek
imadHabash
>> I am wondering if there is a setting that I can change to give me a different options for the appearance properties of selected objects. <<
you can get it by changing SELECTIONEFFECT and PRESELECTIONEFFECT system variables to 0 (zero) .
Command: SELECTIONEFFECT
Enter new value for SELECTIONEFFECT <0>:
Command: PRESELECTIONEFFECT
Enter new value for PRESELECTIONEFFECT <0>:
Imad Habash
Forma Design Contest
AutoCAD Beta
