Any lisp routines for aligning two architectural plans that don't fit?
I know it's a long shot, but I have an architect's drawing here (produced by the same architect in the same drawing, no less), and it has several plan views: existing site, proposed site, building plan on-site with levels etc.
I want to merely align the building plan with levels, to their proposed site plan, but the building doesn't quite fit. Probably a result of pulling around, scaling in one direction etc.
is there any routine for attempting to force alignment between two layouts, even if it's just a best fit? I know it's a long shot, but aligning two drawings that don't fit is always a pain, a opain exacerbated by the fact that it *almost* fits
Cheers!
Alfred.NESWADBA
when you use the command _ALIGN (>>>details<<<)... what do you miss then?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
pendean
Community Legend
Community Legend
How are you using the term "layouts"?
Tried the align command, and it didn't even remotely line up the two parts I wanted, even when provided with multiple source points. I could come up with a much better best fit myself: this put the building footprint, which is similar on both drawings, out by 2 metres.
I'm looking for a command that fuzzes the difference and calculates a best fit scenario, so I'm not moving it round all day trying to find the best compromise
When I say "layout", I'm not talking about the layout tabs. I'm talking about site plans.
