Object Snap keeps turning off
Message 1 of 18
I just downloaded AutoCad 2014 2 weeks ago, and every time that I enter into Autocad to open a drawing, and when I hit "F3" which should just turn on my previously selected object snaps, I'm taken to the screen where I have to manually select my osnaps again. It's as if I didn't have any selected to begin with. I had AutoCad at my previous work and this never happended. It was 2012 version, but the osnaps would save.
The same problem happens when I'm in a drawing (with the osnaps that I want) and then I open a number drawing. I once again have to go in as if I hadn't selected any object snaps. There has got to be a setting that I need to select that will save my object snaps.
Replies (17)
Message 2 of 18
pendean
Community Legend
Community Legend
You have a startup or add-on that is turning off osnaps for you: the clue is it only happens when you open a drawing. Look in your ACADDOC.LSP file or unload add-ons.
All AutoCAD versions work the same way. just like your 2012.
Message 3 of 18
Still i am not clear about it. Please explain how to keep F3 OR OSNAP on.. please
Message 4 of 18
Alfred.NESWADBA
please describe what your situation is and which version and service pack of software you are working with.
A good try at the start: does the same happen when you login with a different Windows user account?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 18
Greetings
I am an employee of a company and we use REBAR base on AUTOCAD. As object
snapping is a major requirement we are having that issue. And we use
AUTOCAD 13 version. If u solve us this issue it aould be a great help for
our team.
Thanks and regards
RAGHAV SANKAR
Message 6 of 18
Alfred.NESWADBA
Please ask the vendor of that add on if this app is turning object snap off. I don't know that app.
>> we use AUTOCAD 13 version
13 or 2013?
Please let us know when the object snap is disabled.
E.g. when you activate ENDpoint as object snap, then you start command _LINE ... is the object snap now active or not?
- alfred -
Alfred NESWADBA
Message 7 of 18
It's AUTOCAD 2013
And Initially i turned on osnap and then placed _LINE command still i am in a situation to turn on F3 again to turn on all the selection (or which ever is required).
And the vendor (REBAR) does not give us any addon to it.
Raghav
Message 8 of 18
Alfred.NESWADBA
Do you mean they don't give you support?
Can you please show a screencast (>>>free to download<<<), make sure we can see the command line and then please follow these steps by just using the command-line:
OSMODE<ENTER>
1<ENTER>
_LINE<ENTER>
0,0<ENTER>
1,1<ENTER>
<ENTER>
OSMODE<ENTER>
so we can see if the variable was changed (or which value it has then just by starting the line command.
- alfred -
Alfred NESWADBA
Message 9 of 18
Hi @Anonymous
Could you confirm whether it is from AutoCAD or AutoCAD Mechanical ?
Which version you are going to do this action ?
Because POWERSNAP option is available only on AutoCAD Mechanical I think so.
Message 10 of 18
It is not autocad mechanical its autocad.
Message 11 of 18
Do you want to turn off the F3 totally ? like the below image.
Or some modes should be turned on ? like the below image.
Please let me know your requirement whether its like the image 1 or 2 ?
Message 12 of 18
Actually in your previous reply you have asked me whether i should turn off
F3 completely but my actual question was "How to keep F3 always on?".
Message 13 of 18
-FDC-
Like F3 you can also click the symbol.
Check the snaps you want and be sure it stays on.
Like this you are able to see it when any command is overriding the settingSnap1.JPGSnap2.JPG.
Message 14 of 18
Hi @Anonymous
As I understood your question, you wants to turn off the snap key F3 always,
If yes, please follow the steps,
1. Go to the below mentioned location in your computer. [ C:\Program Files\Autodesk\AutoCAD {version} \Support\en-us ]
2. Open the lisp file ( acad {version} doc.lsp ) via Note pad.
3. Add this line into the last line. (setvar 'osmode 16384) [need an example, please see the attached image]
4. Save and close it.
5. Open the AutoCAD now, the F3 should be turned off always whenever you open any of the files.
Kindly check and let me know if there is any.
If my post has helps you, please select Accept as Solution.
Message 15 of 18
Sorry supporter.. this is a solution opposite to me. I have received a
solution and i will chech it and close my query.
Message 16 of 18
Alfred.NESWADBA
>> I have received a solution and i will chech it and close my query
One of the most important things in a forum is that you can ask questions, but as others tried to help you please help the future readers with what you have found out!
- alfred -
Alfred NESWADBA
Message 17 of 18
Kent1Cooper
@Alfred.NESWADBA wrote:
.... follow these steps by just using the command-line:
OSMODE<ENTER>
1<ENTER>
_LINE<ENTER>
0,0<ENTER>
1,1<ENTER>
<ENTER>
OSMODE<ENTER>
I would suggest adding the period prefix to the LINE command for this trial:
_.LINE
If the REBAR overlay has Undefined  the LINE command and made its own new definition of it, and if that is what is turning off Osnap, this will call for the native command instead of the different definition.  If when you do it this way, Osnap is not  turned off, then the REBAR thing is what's turning it off.  If that's the cause, you would need to modify its code to remove that, or get a modified version from the supplier, or find an option in it for whether it turns Osnap off, or something.
Kent Cooper, AIA
Message 18 of 18
Alfred.NESWADBA
Absolutely correct, Sir!
- alfred -
Alfred NESWADBA
