DWG TrueView 2015 Default
How do you turn off DWG TrueView 2015 from being the default program when opening a .DWG file.
leothebuilder
I don't think i's a good idea to open drawings by clicking on a file.
To answer your question, you can change the default program to open .dwg files by right clicking a .dwg file, select "open with"
and on the flyout select "choose default program"
pendean
Community Legend
Community Legend
Open the program you want to use, and WIndows will remember it until you open the wrong one again. WINDOWS controls this: the tip above may create more problem for you later or simply put things bak to "wrong" for you.
Be a master of your PC and software: "I don't think i's a good idea to open drawings by clicking on a file." is great advise.
I have tried your solution and it works fine until you restart your computer.
We do not open the file by clicking on the drawing file. We have an excel file (drawing index) that has the cell linked to the file. When the cell is selected the file opens in TrueView. This is correct for most of the employees here but there are (7) that need these files to open in AutoCad.
Yong.Jing
Autodesk Support
Autodesk Support
What's the meaning of "have an excel file (drawing index) that has the cell linked to the file"? Open the inserted dwg file from Excel?
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
ukdxb012
You need to make sure that the AutoCAD users last opened AutoCAD rather than Trueview if you are using DWG Launcher, or alternatively force it by chosing the acad.exe for these users...
Take a look at the following link, i used this myself as we wanted DWG Trueview as the default program to open DWG's rather than AutoCAD, purely for license usage etc. Also its too dangerous to allow users to open dwg's in verticals and accidently save in a newer version... https://designandmotion.net/autodesk/mfg-pages/inventor/autodesk-dwg-launcher-wigged-out-fix/
@Yong.Jing I think thats just it, excel hosts links to the drawings on the server which the user uses to open in an autodesk application.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
This worked like a charm & yes, the excel files are just a list of drawing numberas with the drawing titles to be used as a look up system. The cell that the drawing number is in is linked to the AutoCAD drawing (.dwg) file for easy access Perfect Thanks
