Angular Dim Text Fix
nfisher
nfisher
Trying to figure out if there is another option for the attached photo. It would be cool if the text could arc with the dim style, is this possible?
pendean
Community Legend
Community Legend
There is no DIMSTYLE setting to do that: you will need to use a non-dimension for that effect.
Or... just place the word below the dimension line instead of adjacent the dimension.
imadHabash
Also ... if it's acceptable you can explode it then use the express tool command ARCTEXT , to get what you see in attached image .
Imad Habash
nfisher
Thanks for the help and the options, was just hoping 2019 autocad would of had a dimstyle for this now. np. Thanks!
