command line
command line
command line
There was a time when my command line was there but not visible.
For example, when I would turn ortho on or off (f8) the command line would appear and I could see if I was turning it on or off and then it would go away. Then it stopped doing that. Now I have to have the command line at the bottom of my screen docked.
injineri
you can play with transparency of command line. find it in command lines setting
Capture.JPGCapture2.JPGmmand line.
My command line is docked. Where are the command line settings. I see input settings.
Hi cpfistner,
injineri (Advocate) posted a new reply in AutoCAD Forum<> on 04-12-2019 09:21 AM .
________________________________
Re: command line<>
Reply | Accept as solution<> | Like this post<>
natasha.l
Hello @Anonymous,
You may have command line set to off. Try ctrl+9 to turn it on.
Also:
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Alfred.NESWADBA
Switching ortho modus never turns on of off your command-line.
Can you please show us a screenshot from your AutoCAD application window so we see what you have?
Another trial would be to use command _CUI and modify your workspace and so define your position and visibility of the command-line.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
I understand that selecting ortho does not turn on the command line. What I mean is the command line was like my properties palette. The palette only appears when I move my cursor into it. It would appear showing me it was on/off and then go away.
Presently my command line is docked.
