Plotting a sheet with a polygonal viewport
JoeKidd33
JoeKidd33
We have seen repeated problems with plotting sheets that have polygonal viewports. The most recent will create a file size of 10 mb when using a bluebeam driver. This makes the entire PDF enormous when trying to plot a large set. So, we switched to using the dwg to PDF.pc3 and the file size was much smaller and what we expected, but when we printed a hard copy from the PDF it took the sheets with the polygonal viewports up to 2 minutes each to print. Are others experiencing this? If so, have you found a work around? We are using Civil 3d 2018.
maratovich
Most likely you turned on transparency.
If this is so before the file becomes very large and heavy.
Turn off transparency.
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
JoeKidd33
Transparency was turned off.
