AutoCAD Forum
ANGBASE / ANGDIR
3 REPLIES 3
1227 Views, 3 Replies
ANGBASE / ANGDIR
I want my text to read right to left at 0°. I set ANGBASE=0 and ANGDIR=0 and all is well for a short period of time. Then it changes
back, to ANGBASE=1, ANGDIR=90. It doesn’t matter where I make the correct settings to 0 (my DWT file, my current file, etc.) these
settings go back even during the same drafting session.
Any ideas?
3 REPLIES 3
Has your UCS changed in any way?  A shot in the dark here, but you may want to check to see if your UCS is set to "World".  Or instead of checking, you could just set it as such.  Let me know if that works.
Kent1Cooper
Welcome to these Forums!
They're not changing themselves. There must be some routine, custom command, menu item, or something that's changing them. It could be something that is designed to reset them but doesn't have adequate error handling to change them back if you cancel in mid-routine, in which case it should be easy enough to fix. Look into whatever functions you use that are not native AutoCAD commands. If you notice when it happens, what have you done recently?
Kent Cooper, AIA
UCS is set to WORLD.  Always has been, and that setting seems stable, but thanks for the suggestion.
Forma Design Contest
AutoCAD Beta
