Hello
I've updated AutoCAD 2016 to 2017 but can't use constructionline tool AMCONSTLINES in it anymore. I liked the drag/drop workflow of that tool.
Does it has a different command in 2017 or do you know a different tool?
Thanks 🙂
AutoCAD 2017
AutoCAD 2016
Solved by john.vellek. Go to Solution.
welcome @forums.autodesk.com!
The command AMCONSTLINES is a command available in AutoCAD Mechanical, not in plain (Vanilla) AutoCAD.
So either you have installed the wrong product or you have started AutoCAD with the Vanilla profile instead of the mechanical one.
- alfred -
Hi @Anonymous,
Did you get your problem resolved? AutoCAD (vanilla) has the CONSTRUCTIONLINE command but not the AMCONSTLINES command.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
