AutoCAD Forum
Aligning leaders by arrow ending
4 REPLIES 4
m_kingdon
899 Views, 4 Replies
I am aligning some leaders and I find the text on the right side of this drawing aligns better than the text on the left side.
I know why this is, the text is set up to write from the left side going right, which is fine when using a leader with the text on the right side, but not the left side.
My question: is there a quick way of aligning leaders by where the arrow ends and the text begins, rather than the start of the text?
Mike Kingdon
Civil 3D Zealot
4 REPLIES 4
rkmcswain
in reply to: m_kingdon
I don't see a way using MLEADERALIGN. You may have to do like we have to with Civil 3D labels, and draw a no-plot line and snap the right-aligned text portion of each object to this line.
dbroad
in reply to: rkmcswain
R.K's got a very workable solution.  If however, you've already done the work and you want a workaround, mirror all the leaders about a point, align the same leaders and then mirror them back about the same point.
Architect, Registered NC, VA, SC, & GA.
imadHabash
Regarding text starting.... i think to solve such a problem is when you want to make leaders at the left side and BEFORE writing text just press Left button as attached.
Imad Habash
m_kingdon
in reply to: imadHabash
Hi all, thanks for the answers. Both the line and mirror method work great, but I usually use the line method as I find it a bit quicker for the number of labels I have. I couldn't get the leaders to align differently using text justification, they always align to the left of the text regardless of if I have left or right justification set. I might put "aligning leaders by end of leader" in the future CAD wishlist.
Mike Kingdon
Civil 3D Zealot
AutoCAD Inside the Factory
