AutoCAD Forum
Adding Drawing Block as Plot Stamp
2 REPLIES 2
1485 Views, 2 Replies
How can I add my drawing block as plot stamp?
Example [FOR INFORMATION ONLY] in the format in attached image.
Tags (1)
2 REPLIES 2
imadHabash
imadHabash
HI,
you may try from PLOT dialog .
Imad Habash
HI,
Imad Habash
pendean
pendean
Community Legend
Community Legend
PLOTSTAMP command only does text (predefined parameters and FIELDs too). Look it up in the program and in HELP.
IMAGEATTACH command is or attaching images if you want to do that, place it on a unique layer you toggle on/off when you need it.
HTH
HTH
AutoCAD Inside the Factory
